Hi Karamba3D team, I am facing a persistent Karamba loading issue in Rhino 8 Educational on Windows 11. When I start Grasshopper, Karamba either gives the error Could not load 'karambafeb.dll', or after trying the MSI installer, Karamba does not load into Grasshopper at all and no Karamba tab appears.
I have already tried uninstalling Karamba from Package Manager and Windows Apps, deleting the full Karamba package folder from the Rhino packages directory, clearing Recycle Bin, restarting Windows, reinstalling VC++ Redistributable x64, checking that there are no old karamba.dll or libiomp5md.dll files in Windows system folders, disabling SpeckleConnector.gha, testing both Karamba versions 3.1.60309 and 3.1.51222, turning off automatic package updates, and confirming that there are no duplicate Karamba.gha files outside the expected Karamba installation folders.
I also tested karambafeb.dll with DependenciesGui, and it loads successfully there. I tried Rhino in both .NET 8.0.21 and .NET Framework 4.8.9325.0 using SetDotNetRuntime, and also launched Rhino with the Karamba installation folder manually added to PATH, but the issue remained.
Finally, I tried installing the official Karamba3D_RH8_NETFramework_3_1_60309.msi. Grasshopper then reported that it could not load KarambaCommon, Version=3.1.60309, even though KarambaCommon.dll exists in the same installation folder. After launching Rhino with that folder added to PATH, the error disappeared, but Karamba still did not load and no Karamba tab appeared.
Could you please advise what could be causing this and how I can properly repair the Karamba installation for Rhino 8?
