- There are 135 rigid body modes in the system. This means some parts can move freely without causing deformation.
Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.
I am getting this error in analyze model component in Karamba3D. I tried to check the eigen mode as suggested, but am not able to understand what is causing the problem.
I have also tried changing joints and supports but it doesn’t works. I am trying a hyperboloid truss type of structure.
This is the image that can be seen in the eigen modes.
I need urgent help, any help will be appreciated.
This is the grasshopper file.
Hyperboloid Bamboo Tower Forum.gh (72.3 KB)
