Karamba3D erro (help)
I’m developing a study on Karamba3D, but it’s giving this error:
  1. There are 82 rigid body modes in the system. This means some parts can move freely without causing deformation.
    Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
    If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
    When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.
Can someone please help me because I don’t know what I did wrong.
test_karamba3d.gh (104.9 KB)
I improved my code development, but still I couldn’t get out of this error. If anyone can help me, I would be grateful.
test_karamba3d.gh (114.3 KB)
hi, all of your elements are not split at their intersections. This means that they are not properly connected
