Hi, I am trying to model and analyze using Karamba a series of trusses. I have set up the model, but when I try to go and analyze I get an error that says:
“1. There are 138 rigid body modes in the system. This means some parts can move freely without causing deformation.
Try to use the ‘Eigen Modes’-component and activate the display of local coordinate axes: The first eigen-mode will be the rigid body motion.
If this does not help, check whether you have a pinned support directly attached to a hinge. A hinge introduces an extra node which may cause the problem.
When analyzing a flat shell structure one has to lock the rotation perpendicular to the plate in at least one node.”
From what I have seen on the forum, other people who have received this error had geometric issues with them having duplicate points causing the structure to not be fully connected. I tried to identify whether this was the issue in my case too, but could not seem to figure it out.
I am using Lunchbox in order to create my trusses. I was wondering whether this could in any way interfere with the Karamba analysis?
Any help on how to sort this problem out would be greatly appreciated
the grasshopper file and associated model are linked below.
Timber Non-Form Active Improved.gh (27.8 KB)
Model.3dm (44.3 KB)
