The Beam View component sometimes makes zigzaggy render meshes as in the attached images and file. I am not sure what this is caused by. The attached file uses Imperial units and input in feet. Thank you very much!
Karamba model 3.gh (88.0 KB)
Hi, your model is assembled properly. You have parts which are not connected properly. I also do not understand what the small segments are at the base of the columns and what the boxes are for. Please see this guide on how to find out which parts are not connected properly. 3.1.4: Connected Parts - Karamba3D 2.2.0
Hi Matthew
That worked, thank you very much!
Chris
