Simple model
Hi!
I’ve updated “01_InputCurvesAsTruss" to the new Karamba 3D version,
but “BeamView” and “BeamDisp” I don’t know how update.
However there are expected values ​​that match, but there are others that Karamba 3D doesn’t give me.
What’s the problem?
Thank’s
Vigues 2.gh (110.5 KB)
You just need to replace it with the same component. However this definition is from a previous version. Did you check Input Curves and Analyse as a Truss - Karamba3D
Vigues 2-mt.gh (101.0 KB)
Vigues 3.gh (113.9 KB)
I only change the model, but give error… Only change from 11 to 8 beams. :exploding_head: :tired_face:
did you follow the instructions as instructed by the component?
The eigenmodes clearly shows that you have issues where you have a “quad” segment in your truss, which means that it is instable. You need to triangulate it.
Please refer to the warning messages and try to troubleshoot it
Thank’s! I’ve solved it! But I don’t know how…
Both files are the same, but (vigas 3(1)) fails and (viguas 3) runs well.
Vigas 3 (1).gh (117.8 KB)
Vigas 3.gh (117.0 KB)
Now the problem is that the expected results are not the same as what Karamba offers me.
Tasca.gh (59.4 KB)
Hi! I’ve done 4 exercices in one file. The expected results of “viga Howe” are from my teacher. There are a good results for sure, but don’t are the same that Karamba gives to me. :cry: Why???
Thank’s!
Finally I’ve found the error!!!
I’ve unlocked Tx in the unions and all goes well!! :tada:
