HI everyone, Im not too sure what is the issue with this , I was trying to get a structural analysis out , but this assemble model component turns red and there is no results. May I know how to solve this ? Thank you!
file script.zip (13.7 MB)
Hi, i think you are analysing the structure incorrectly. The script is unable to load on my machine as it is too heavy
Karamba3D takes axes beams or axes surfaces as input for analysis. In this case, you have input the bounding mesh as your geometry, which will give you incorrect results (unless you intend to analyse it as though it is hollow). If it intended to be solid, then you need to extract the axes surface of each wall face.
