Faulty analysis, scripting issue
Hello!
I am a student learning Karamba3d and have run into a scripting, modeling issue.
With the script, model that I currently have I am running into the following issue and am unable to run an analysis on the model.
I have tried a few varying approaches, including rebuilding the model several times, to try to resolve the issue but have been unsuccessful.
I would greatly appreciate any help, leads as to how to resolve the issue.
The first thing I can see is that you have multiple models, first try to flatten all your inputs. Then use the Analysis or Eigenmodes component connected to the ModelView component to check where there might be failure in your model.
Hi your model is kinematic and parts of the model are not connected together. Please go through your model and check everything otherwise you cannot calculate it properly
