Kangaroo2 Floor
Hi
I’m a little bit new to kangaroo.
I am trying to put a mesh on a geometry using kangaroo 2, I used the floor component but it does not seem like it accepts geometry.
The floor component is a bit different from other goals in that it automatically applies to all points in the simulation - you don’t need to specify particular points.
Aha, Thanks for your reply.
So is there a method to release a mesh on a geometry like the cloth simulation ?
If you mean draping over a solid object, yes - see the drape.gh example here:
edit - another example here:
This is what I am looking for. Thanks a lot !
