Kangaroo mesh is only coming out as the mesh lines not as a meshed surface
Hello all,
Im not sure why but my mesh is only coming out as the grid lines not as a surface, is there a way to get this to show the surface correctly?
For Josh.gh (40.8 KB)
You need to either Internalise your Geometry, or upload the .3dm file you referenced your geometry from.
I guess you’re looking for Show component. you need to connect your mesh to G input and then use it’s output as a GoalObject.
Ah great thank you! I knew it would be something simple
