But when i run the Kangaroo Engine, my particles fall down because my springs disappeared.
When i connect only one of my anchor points, i can see them…
I recommend you to get the current version of kangaroo http://www.food4rhino.com/app/kangaroo-physics I cannot open your file because I dont have the old solver anymore, but from what I remember in this version there’s an AnchorXYZ component, I think you should connect your anchor points into this one (the curve’s end points) and then into the solver. cheers
I downloaded Kangaroo 2 but this is not where the problem comes from. When i use Kangaroo with a meshplane, there is no problem (as in kangaroo 0.099).
So it might come from the fact that i am using a polyline and not a mesh from what i understand.
Because when i want to apply the same logic to a single line, nothing happen this time…
