Anchor points
Hi there,
I have been going through Kangaroo and sometimes i have problems with the anchor points both Kangaroo2 and Kangaroo 1. The reason is that when I set the anchor point from a mesh and move them away form the mesh plane kangaroo does not recognize them. The attached example is a bit different and complex, but basically when i reference the points from a mesh onto a curve not contained within the mesh plane and set those points as anchor point, well those anchor points are just ignored when i run the simulation.
any idea why?
Anchor%20points
Test-1.gh (19.2 KB)
thanks in advance.
Hi @joseluissp23,
I am using Kangaroo2 here, seems to work just fine, have a look:
Test-1_reLina.gh (19.0 KB)
best,
Lina
Hi Rina,
thank you very much for the help. the target input within the anchor point parameter was the missing part. Now works perfectly.
Regards,
Jose
