Kangaroo 1 vs. Kangaroo 2
Is there any changes to Kangaroo 1 when used with Rhino 6? I can not see the Kangaroo Engine after I downloaded the Kangaroo Physics 0.099. It seems that only the solver of Kangaroo 2 can be used. Is there a way around this? Thanks!
Hi Patricia
What are you trying to do?
I’d recommend using Kangaroo2 now. If there is some example from the old version you are looking at I can help with an updated one.
Hi Daniel,
Just out of curiosity, I was trying to compare the old one with the new one. No worries, I had solved my problem and was able to use the Kangaroo engine from the old version. Thank you for your response.
