Hi all, does anyone know if there is a way to output a jpeg from rhino (ViewCaptureToFile) to be on scale?
I am trying to set the zoom of the viewport so that it’s on scale using the the Zoom1To1Calibrate but when it comes to export it, I can’t find the resolution to keep the view on scale. Is there a mathematics formula that could support me in this? Does anyone found an easy and quick workflow to do it?
Thank you!
if you use the print command you can use it to print the viewport at a 1:1 ratio and the like. I would start there. Jpeg is generally never “to scale”. It uses pixels which are determined by the size of your screen.
Sea
