r.weenink
(R Weenink)
#1
Hello all,
I’m probably doing something wrong. But i dont seem to be able to join 2 SubD surfaces.
I’m tying to use the join command for this operation.
Another problem i encounter is that i end with an open object after extruding these surfaces.
Any ideas?
Kind regards Reinder
You can’t join a vertex to an edge.
I pulled the two SubD faces apart to make it visually clear that there is a point missing.
This problem can be solved by inserting a point on the red outline.
Next you can use stitch to stitch the points.
Or join, when the vertices are already coincident.
r.weenink
(R Weenink)
#3
Thank you for the reply! this solves the problem! I’m sorry for my slow reaction.
kind regards
Thanks, in case your problem is solved, please click the Solution box
