hi,
im so rusty…and novice.
how to i use log between 3 curves? one is generated between the to originals, but i cant plug the 3 curves into the loft…
curves compiling.gh (11.6 KB)
Moved to Grasshopper category
You can hold down the SHIFT key while connecting additional wires to Loft (or any component). From what I can tell though, each Crv param is two curves so collectively they overlap and will cause a problem for Loft.
