Join beams
Is it possible to join multiple beams into a single beam ? This is not very convenient for manufacturing. I had to explode curves from grasshopper to be able to send it to revit because of tolerance. The result is not good.
Revit isn’t a fabrication software, which why it is very typical for there to be 2 or 3 structural models with a project (original Arch, Shop Drawing/Coordination & Fabrication). Tekla being the most popular structural fabrication software in my experience.
The same goes for curtain walls, you can’t even get close to a fabrication model in Revit due to the segmentation.
That said there are ways to draw atypical members in Revit. This Zach Kron classic comes to mind..
Hi @Bilan_Gumus,
Have you tried the following
Yes i did, but there are to much problems, beams missing, cpu usage to much, + some beams are deforming to respect tolerance wich changes the projects original design. .
