Hi
I’m using the ‘Add structural beam’ component and am finding it fails without explanation. Annoyingly the components aborts all of the created elements, even if only one fails and the error tracking is set to skip. In the example below, item at index 99 fails with no explanation. It is just an arc that looks correct and isn’t smaller than 0.8mm (as per Revit tolerances).
Any ideas what is causing this?
If I bake the curve and reference it in, it works. Really strange…
Using the latest RIR release cadidate 1.22.89
