HELP- improve Display-Technical quality
As in the subject I’m getting poor visualization with the Tech Draw display style.
I set a custom mesh for the object and the shaded view is very good and sharp.
You see in the image that some line are disappearing also if are proper surface edge.
this is the rendermesh:
Thanks
I can’t troubleshoot an image.
Hi Wim,
you’re right, this is the file:
Evidenziatore_OK25.3dm (5.3 MB)
FWI:
Rhino 8 SR16 2025-1-21 (Rhino 8, 8.16.25021.13001)
License type: Commercial, build 2025-01-21
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP  - Plugged in [92% battery remaining]
  Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 4-18-2023 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
  Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.88
        - Secondary monitor is laptop's integrated screen or built-in port
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 3-13-2024
  Driver Version: 31.0.15.5188
  Z-Buffer depth: 24 bits
  Total Video Memory: 8188 MB
  C:\Users\gttrc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp	"NVIDIADenoiser.Windows"	0.4.3.0
  C:\Users\gttrc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\BotchaXRhino\2024.2.3\BotchaRhino.Rhino8.rhp	"BotchaRhino"	2024.2.3.0
  C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp	"V-Ray for Rhino"
  C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp	"SolidTools"
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp	"AnimationTools"
  C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.16.25021.13001
  C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp	"PDF Export"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.16.25021.13001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\Calc.rhp	"Calc"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Hi Skysurfer -
Thanks.
When I open that file, all details are set to the Wireframe display mode, indicating that you have a custom display mode that you use for these. From the image, that looks quite a bit different than the default Technical display mode, and since I can’t reproduce the issue with that default mode (with hidden edges turned off), I probably need an .ini file for your custom mode.
Here we are:
Vista Tecnica renderizzata grigio.ini (14.9 KB)
Hi Skysurfer -
Thanks.
This is very inconsistent on my end. Sometimes things look fine, other times not so.
I’ve put this on the list as RH-85840 Display: Inconsistent Technical Line Display
I don’t think this is a simple fix, and since this is much more pronounced with your custom display mode, I’d recommend to use default display modes on this model for the time being.
Hi WIM,
Thanks to taking care of this.
Let me add one info: this style come from an V7 ini file.
It may be this the issue?
I’ve noticed many issues with old display styles.
Hi Skysurfer -
I wouldn’t think so but we’ll see what Jeff finds.
