Help I can not see curves and polylines
I am having some trouble and cant seem to find out why. I can not see curves and polylines on viewport. Here is my systeminfo. Id be really grateful if someone can help. Thank you!!
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Evaluation, build 2025-04-10
License details: Cloud Zoo
Expires on: 2025-07-11
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 6GB Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 561.19
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-11-2024
Driver Version: 32.0.15.6119
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
Hi -
Is that the case no matter which display mode you use in the viewports?
Do you see a preview while you are creating a curve but that then disappears when you are done drawing?
hi,
Its the same in all viewports, and yes it just disappears
Pls check out the Curves option in the Display Panel,
Dumb question, but it seems your x and y points are relatively large. What are your units? It shouldn’t be an issue, especially if you’re not tens of thousands of units away from the origin. Try drawing the same thing on a Construction Plane that passes through the world origin point.
EG, invoke “cplane” select “world” “top” , find 0,0,0 and go there to draw your polyline.
Believe it or not, but I see this come up a surprising amount.
Good luck!
