Hello! Here to report a bug! bump maps display weirldy while looking at them from diffrent angles while other angles are fine. (in Rhino WIP)
(There is no problem when saving the file as a rhino 8 file and reading it in rhino 8.)
This is supposed to be a brick texture. As you can see the texture breaks, appearing as if it’s stretched. Looking at it from above we can see how it’s supposed to look.All I did was position the camera differently.
Also, the bump map does not appear at all when changing to raytraced.
No problems in Rhino 8.
The file size was too big so i exported the problem objects. Problem persists although not as noticable when isolated
I’ll Attatch it. Also my system info.
specs.txt (2.0 KB)
Problem Model 1.3dm (354.5 KB)
All is well.
