Issue with modifying slab by moving control points
I have a slab created from a curve.
I want to modify it by moving control points:
So I select points:
And move them upwards. After this slab disappears:
Though it still exists and I can select control points:
But if control points are off, the slab is invisible.
Please fix the bug.
Disappearing_after_move_points.3dm (2.5 MB)
Disappearing_initial.3dm (2.5 MB)
Is it possibly crazy big? That’s what happens to my slabs sometimes. Closing the file, reopening and then updating the object will often fix the crazy size issue.
No, it’s not that big.
You can check the size in attached files.
I’ll try updating object, but still this is a bug.
Closing and reopening file is too expensive.
Отправлено со смартфона Samsung Galaxy.
-------- Исходное сообщение --------
От: Rheinason via McNeel Forum mcneel@discoursemail.com
Дата: 30.01.19 2:52 (GMT+03:00)
Кому: gvanka@gmail.com
Тема: [McNeel Forum] [Plug Ins/VisualARQ] Issue with modifying slab by moving control points
Rheinason
    January 29
Hi @gvanka,
Thanks, I reported the issue to the developers.
For now, if you create the slab again but using a polyline it seems to work fine.
Regards,
Hello, we have fixed this bug in VisualARQ 2.4.1, that is already available for download: VisualARQ 2 - Version 2.4.1 released
