I am trying to copy a slab from one file to another, but when i pasted it in the new file, it appeared for a split second then disappear. I try to reconstruct it by extracting the curve outline, that is not showing too.
Attached is the file with the disappearing slab, can someone have a look?
Hi @Rui_Hang_Yong1 The slab shows up correctly when I open your file. Can you share the file from where you are copying that slab, so I can repeat the same process?
