I have a DXF file which I want to import on to a new rhino document. When I try the command “import” and select the DXF file, the drawing on the imported file does not get drawn properly. Some of the objects are way off.
What might be the problem?
Hello - we’d need the dxf file to try here - can you post it here or send to tech@mcneel.com to my (Pascal) attention? If it is very large, please zip and send to www.Rhino3d.com/upload
Hi Wil - are the incorrect objects all dimensions? By ‘off’ do you mean incorrect locations or? Here is looks like some dims are oversized and colliding - is that the problem?
Hi Wil - thanks, got it, so, can you also send the file you are importing to? If it’s big you can remove all the stuff and send the empty file… I should be able to reproduce it with that.
Hi Wil - thanks - I got it - actually, I was hoping for the file before the insert/import of the dxf - there is something peculiar, to me, about the blocks in the file after the import, but is the file completely empty before the import? Or are there block definitions already in that file, even if unused, before you import? (BlockManager will tell you - make sure to show hidden blocks.)?
Here. if I delete all the stuff in your file and Import the dxf I get what you get but if I delete all the stuff in the file and Purge all the block definitions, then importing works as expected…
I used the method you have mentioned to check the file which I am trying to import to and it seems to be empty. I actually tried deleting the stuff and using the Purge command, then re-importing it again and it worked. I guess I will stick with this solution.
