Issue With Clipped Block References On Locked Layer
When a block reference is clipped by a clipping plane and on layer that is ‘locked’, the block reference does not display a solid material fill.
Block reference is clipped by a clipping plane and the layer it is assigned to is “unlocked”
Block reference is clipping by a clipping plane and the layer it is assigned to is “locked”
Hi Brady- thanks, I’ll see if I can repeoduce this - is the display mode a default ‘Shaded’ one? Can you please run SystemInfo in Rhino and copy paste the results here?
It doesn’t seem to matter what display mode is being used. In fact, when set to shaded mode the block instance turns black and becomes nearly impossible to see, maybe another bug? The mode I am using in my screenshots is a custom version of rendered mode.
Yep, I see this, thanks. RH-70873 Blocks on locked layers do not clip properly
So far this is not a problem in the WIP builds.
Thanks for the help.
Here is my system info
Rhino 7 SR24 2022-10-10 (Rhino 7, 7.24.22283.10361, Git hash:master @ 8a36c0fc6c4c6b22ef2530cd9aa33ae6661fa64f)
License type: Commercial, build 2022-10-10
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 9-12-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2022
Driver Version: 31.0.15.1740
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22283.10361
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.24.22283.10361
C:\Users\brady\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
