Display bug with locked/unlocked block instances
Ran into this display bug where locking/unlocking one block instance changes the display of other instances of the same block. The affected blocks can still be selected since they’re unlocked, but they display gray as though they were locked.
Display Bug.3dm (168.6 KB)
Hi measure,
Can you provide steps to repeat? locking and unlocking randomly isn’t reproducing in 8.15.24325.02001
Thanks
  1. Open the file I provided.
  2. Unlock the bottom instance and the top four instances appear to unlock as well.
  3. Lock the bottom instance and the top four instances appear to lock.
The problem persists through saving/closing and reopening the file, and if you copy/paste the block instances into a new file, the problem follows.
Please run SystemInfo in your Rhino command line and post the results.
Video
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 112GB)
.NET 7.0.16
Computer platform: DESKTOP
  Primary display and OpenGL: NVIDIA Quadro K5000 (NVidia) Memory: 4GB, Driver date: 6-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 475.14
        - Secondary monitor attached to adapter port #0
        - Windows Main Display attached to adapter port #1
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 2x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 6-10-2024
  Driver Version: 30.0.14.7514
  Z-Buffer depth: 24 bits
  Total Video Memory: 4 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.13.24317.13001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
@Measure - I believe this is fixed in the SR 14 Release Candidate. Can you test?
– Dale
I sent him 8.15 and got confirmation of the fix.
