Not sure if this is a mac issue or a more general one, but since I’m working on the mac at the moment, I’m posting it here…
I’m having trouble doing a boolean difference. The objects are in bad diff.3dm (505.7 KB). Trying to make a complex hole in a box.
The object for the hole was created by:
- extruding a star-shaped curve for the main body
- lofting that curve with larger/smaller circles for the end pieces
- bool union on the above 3 objects
- offsetsrf on the result to make a slightly larger object for the hole
I realize this is a relatively complex object to be using for a diff… that said, is there any way to tell exactly why it’s not working? I’ve noticed that several of the other manipulation commands don’t work either… wire cut and bool intersection, to name a couple.
FWIW, the object is the end of a shaft, which needs to insert into a matching hole on a handle. The slanted ends are to make it so that it can be 3d printed without supports. The star shape itself diffs just fine.
brian
