when I attempt to use the import geometry command to bring in a .dxf there seems to be an issue. I see a red X when I upload to the online viewer, and when I look at my grasshopper script there is an error (Exception when reading file: DXF file version not supported : Unknown.) Could you look at my .dxf file and let me know what might be causing this issue.
DXF-file.dxf (22.9 KB)
The DXF import is currently limited to polylines and meshes but we are working on ShapeDiver plugin upgrade which will come with improved import options.
For now, export the DXF as polylines in order to import them to ShapeDiver. Do you get the DXF from Illustrator or any other application?
