Isometry in Cycles (Cyclometry?)
Fun blend of simple geometry and projection versus an advanced render engine.
So this is done completely in Cycles? Not composed of a render and linework in illustrator/photoshop etc?
If so it’s nice for conceptual diagrams.
Cool! Could you elaborate a little bit more about the process?
Thanks,
JosƩ
Yup, pure Cycles ViewCaptureToClipboard result.
Groundplane is just diffuse with a single grid cell texture (bitmap, hand drawn in Paint.NET), single HDR environment, and a bunch of CurvePiping for the edges with a pure black material. Nothing fancy, though obviously I did have to figure out which edges should get which thickness manually.
Oh, and the ā€œISOMETRYā€ is a decal.
When will it be available?
Vittorio
Cycles is available as a display mode in the RH6 WIP.
Ah, bummer, I thought the thicker ā€œsilhouetteā€ edges were something that the display mode figured out… --Mitch
The display mode is called Raytraced.
Nope… good ol’ fashioned human labour.
Incidentally here’s a screen-cap of the viewport:
What kind of rendering device do you use?
CPU, I get corrupted display (and sometimes crashes) when I try my AMD.
Device 0: CPU > Intel Core i7-6700K CPU @ 4.00GHz > 0 | False | True | False | CPU
Device 1: OPENCL_AMD Accelerated Parallel Processing_Tonga_01:00.0 > Tonga > 0 | True | True | True | OpenCL
You could try setting environment variable, see
for info.
@DavidRutten
your rendered view looks nice - would you share the setting? maybe even add this as another option to rhino wip?
That seems to work, adding the environment variable adds a third ā€˜device’ to my list, which if I select it is a one-way ticket to hard-crash central, but selecting the ā€˜old’ AMD device now works. It’s a little bit faster than CPU, not hugely. Is that expected?
I have to say it’s rather nice not having the ventilator kick in right away while using the card.
It’s standard settings, using one of the standard HDR environment maps.
@DavidRutten
ok, sorry, don’t get it. do i have to add the HDR somewhere in settings -> view -> display modes -> rendered? or somewhere else?
That’s a labour of love. Looks amazing… I’d have that as a poster or a screen saver, but then I’m old(er) and it brings back memories :smiley:
Render settings panel (the tabs where one can have layer manager, material manager etc), enable Skylighting and either set a custom environment, or let it use the same environment as the background.
