Isocube pattern generation idea?
I am trying to find a way to produce some image like this one:
Where would i start? Or does anyone have an idea how to generate sth like that?
Thank you so much,
Pcace
Do you want to create a 3d object or a 2d drawing?
In the end i just want to create a 2d drawing, but if i would have to go a detour via 3d its also fine with me.
Cheers
Hello
it is easy and complex at the same time. Easy because it is simple rules. A cell can touch a cell by face/edge and points. But it is not allowed that a cell (cube) touch another cube just by edge and/or point. But here it seems that cell can be isolated.
it is also not possible to group cells (to be confirmed). It seems very similar to a Maze in 3D.
I did something like that with continuous cell.
Here one way of doing, I use Maze from Parakeet as it is available. I have lot Maze tools but I no more publish them. I also use Human for the lines.
I use the main Maze Pattern, add cubes on its, merges all these cubes in one object, then make a parallel view in Rhino to have the good angle of view.
cube maze iso.gh (22.3 KB)
I am speechless! Thank you so much!
I will look into that in the next days…
It definitely looks exactly like what i was looking to do!
Cheers pcace
It is also possible to suppress the “grey” using an emissive material
please fix the title
geration > generation
Sorry, i am writing this on a tiny iPad :frowning:
Thanks for editing this out!
You’re from another planet or realm Laurent!
Hello
it works with my Nautilus Maze components, if you choose the wall.
I added a camera crane from Heteroptera, so you can have all the iso view easily
cube maze iso (1).gh (26.4 KB)
I was just looking at how to make mazes with my 2D curves…
