I haven’t found a way to get this list to refresh or sort alphabetically. Along those lines I notice there isn’t really a standard way to setup dialogs and make sure the symbols and approaches are consistent from one to the other. And sometimes that makes it harder to figure these little things out.
I haven’t found a way to make this not refresh or not sort alphabetically.
Please share your SystemInfo data and a relevant 3dm file.
The files I have are too big to post but I’ll work on getting something together.
This is the list you access from the properties NOT the block manager’s list (that one sorts just fine). I’ve attached a file - it does it from a fresh file so I think we might be talking about different lists. I’m whipping up a script right now actually to see what that does. If this has a block table (of sorts) similar to AutoCAD this might actually be really easy to fix.
Blocks not in order.3dm (90.7 KB)
C++ might have a sort function RhinoCommon doesn’t. Sorting lists might cause other issues. For example, there might be a bug where layers get out of sync (I swear my section styles shifted) - I don’t want to talk about that more until I actually confirm it. What I’m getting at is that maybe sorting the list (array) is a bad idea. It’s likely that the order is very easy to control on the UI end.
Hi -
I see this was changed for Rhino 9.
I’ve opened the YT and asked if it is possible to backport to Rhino 8.
→ RH-95083 Properties: Sort block instance properties dropdown alphabetically
RH-95083 is fixed in Rhino 8 Service Release 37 Release Candidate
