Is there a way to export text in Rhino as curves (for Adobe Illustrator)?
The reason behind my question is, whenever I bring text into Adobe Illustrator from Rhino OSX, it’s all over the place (most likely Illustrator’s fault, not Rhino’s). But if Rhino could just export the text as curves, I assume Illustrator wouldn’t have a problem as it never does with just curves.
Thanks
Not directly. You would need to make the text using the TextObject command (as curves) instead of using the annotation command.
Thanks John, that’s actually pretty useful – not the ideal solution but gets me there nonetheless.
In Windows Rhino, you can Explode annotation text to turn it into outline curves. Mac Rhino can’t explode text yet. I don’t know why.
I’ll get it on the list.
what command of text to outline curves in window version?
Simply use the Explode command.
And I think that also works on Mac now as well…
When is used command “explode” sometimes shapes are not correct. Better is to use TextObject command.
It’s still not working on the Mac version.
I’m on Version 8 (8.12.24282.07002, 2024-10-08).
When I explode a text with the Explode command, it gets way bigger than it was:
This is the result of the What command for the text object:
text
  Object name: (not named)
  Layer name: def
  Render Material:
    source = from layer
    index = -1
  Attribute UserData:
    UserData ID: 563238F9-C201-411d-A7B1-13895A0317AD
    Plug-in: Rhino
      description: AutoPointsOn
      saved in file: no
      copy count: 1
  Geometry:
    Text
    (ON_Text)
      Point: (-52.7866,118.313,25)  X-axis: (1,0,0)  Y-axis: (0,1,0)
      Height: 2.50000 meters
      Wrapping width not set.
      Justification: center,middle
      Runs: 1
      Run 0:  - Font: Arial
      	Text : NW
      Not wrapped
      Annotation style:
        Style index: 0
        Style id: 7BA6CC57-BB01-468f-8560-A17C6072A86C
        Text height: 2.50000 meters
        Model space scale: 10
        Scaled text height: 25.00000 meters
        Arrow type:   Solid triangle
Any thoughts on how to work around this issue?
Not supposed to happen… Can you post a file with that text object before exploding?
Sure, you can download it from here:
https://www.dropbox.com/scl/fi/ei1ovbjfhd4nu199ztej1/Rhino-Forum_text-example.3dm?rlkey=o20m88u15ur4765f6s8ilcgnn&dl=0
More context: I was baking it from the Sun Path component of LBT 1.8.
The Rhino geometry came from the highlighted node:
If you set the model space scale to 1, exploding the text will stay the same size. Not sure whether this intended behavior or not.
This is due to the combination of baking to an annotation style that has the model space scale set to something else than 1 and at the same time having annotations styles set to not scale in model space.
RH-84650 Text: Explode To Curves - Size Issue
Thanks @Helvetosaur & @wim for the replies and for logging the issue!
RH-84650 is fixed in Rhino 8 Service Release 14
