Illustrator Export - Text to Curves
I’m having problems with text justification & alignment when exporting to Illustrator. It occurs to me that I could get around this by converting all text to curves before export, but I don’t want to do this ‘destructively’ - i.e. I don’t want to permanently change all text to curves in the Rhino file.
Is there anything that would stop me doing this via a script, and is there an alternative to exploding the text to create the curves? Reason being, I’ve found in quite a few cases that the output from exploded text doesn’t look much like the original text.
Hi Matt -
Copy Pause InPlace Explode
should help, if I understand what you’re doing. I do not think there is a better alternative to Explode - the displayed text is sometimes not the same as the curves - I know this has come up before and I don’t recall the reason, but I’ll ask. It might be worth a test in one if these cases to make the text as curves in TextObject and see if that is different from Explode of the same sized Text.
Hi Pascal
Yeah - that’s the kind of thing I had in mind, followed by a few Undo’s to get Rhino back to the pre-export state.
This is typical of what I see when exploding text to paths though. Original on the left, post-Explode on the right:
I can’t think of an easy way to replace Text with _TextObject generated text prior to export, so the whole thing may be a non-starter. Exploding hatches to surfaces isn’t what I’d want either.
Wow - that is pretty extreme - can you email me what you show in the image?
thanks,
On its way. I see this all the time, no matter what the font, so I wouldn’t say it’s ‘extreme’. For one-offs, I replace Text with TextObject curves, but I’m exporting a lot of these things atm and that’s not really viable, especially as I often need to edit text in place several times.
Hi Matt - your example opened here as plain Arial, and explodes to clean curves… even way off in space as they are. Still poking…
Is there any solution for this?
I have the same problem exporting something like this
Hi Anastasios -
This thread is 8 years old…
Please provide both a 3dm file and the output of the Rhino SystemInfo command.
do you need to bake it and then send it ?!
I dont have a 3dm file, i just bake this and the export
2 dj_02.gh (18.3 KB)
