Is there a full screen presentation possible (with rendered models) like in the rhino viewer. (models and layers selectable via touch screen?
Is there a full screen presentation possible (with rendered models) like in the rhino viewer. (models and layers selectable via touch screen? This would be a very helpful feature to present a model to clients. No tools, no bars visible, just the model for presentation?
Hi - have you tried the -Fullscreen command? Use the dashed version to see the options for that command.
Thank you for your answer. I know the FULLSCREEN command. It hides to much. I can`t change layers to select other objects or change textures just for presentation purpose.
As @wim mentioned, you can use the dashed version of -Fullscreen command to see the options which first of them let you control the layer panel visibility. keep in mind that you need to turn on the layer panel before using Fullscreen command. you can also use this macro:
_Lyaer _-Fullscreen _ShowLayer=_Yes _Enter
