I made a library of objects (single 3dm file with lots of block instances in it) I’m using regularly on models I’ve been building and I’m wondering if it’s possible so assign weight data to every single block instance separately and when I import those blocks to another file, weight and material datas will also come along with the blocks. When I was using Rhino 5 and V1, I tried doing it but I could only import the blocks without any weight data attached to them so I had to assign the weights every time by myself which was very time consuming. So I’m wondering if it’s possible now with Rhino 6 and V2?
Thanks in advance.
