RhinoCommon API C#: How to import block instances
Can you please tell me how to import block instances correctly?
My task is to load a .3dm model into a RhinoDoc, but before adding the geometry, I need to modify some of the input data (like materials and transformations). I’m currently stuck at the point of importing block instances properly.
When I run my code, doc.InstanceDefinitions.Add(...) seems to add one extra object - I expect 3 block instances, but I get 4. Also, the transformations applied to the instances are incorrect.
Here’s a simplified snippet of what I’m doing:
File3dm model = scene.Floorplan.Model;
foreach (var idef in model.AllInstanceDefinitions)
    var geometryList = idef.GetObjectIds()
              .Select(id => model.Objects.FindId(id).Geometry.Duplicate())
              .ToList();
    int idef_index = doc.InstanceDefinitions.Add(idef.Name, idef.Description, Point3d.Origin, geometryList);
    if (idef_index < 0)
        RhinoApp.WriteLine("Unable to import block from file.");
foreach (var obj in model.Objects)
    var geometry = obj.Geometry.Duplicate();
    var attributes = obj.Attributes.Duplicate();
    if (geometry is InstanceReferenceGeometry instance)
        if (scene.Floorplan.Model.AllInstanceDefinitions.FindId(instance.ParentIdefId) is InstanceDefinitionGeometry definition)
            var guid = doc.Objects.AddInstanceObject(definition.Index, instance.Xform);
    else
        doc.Objects.Add(geometry, attributes);
First off importing blocks from a 3dm model can be a bit of headspin – its a lot easier just to use RhinoScript’s insert command - this might be better if you’re importing a whole “model”, once its imported you can manipulate it. If I remember right the _B part imports as block, so potentially easier to manipulate objects since you can operate on the objects within the block, and then you could explode it when you’re finished (if you no longer need it as a block).
var model = fileName
string insertCommand = $"-_Insert _F _L _L \"{model}\" _B 0,0,0 _Enter _Enter";
RhinoApp.RunScript(insertCommand, true);
If you’re set on loading from the model, then you can tweak your code a little bit:
          .ToList();
    var attributesList = idef.GetObjectIds()
        .Select(id => model.Objects.FindId(id).Attributes.Duplicate())
        .ToList();
    int idef_index = doc.InstanceDefinitions.Add(idef.Name, idef.Description, Point3d.Origin, geometryList, attributesList);
    if (idef_index < 0)
        // Check if instance parentIdefId matches the current idef
        if (geometry is InstanceReferenceGeometry instance && instance.ParentIdefId == idef.Id)
            // Only duplicate attributes when we need them
            // If there is a match, create instance using the the new definition we created
            // not the definition from the model we loaded
            // also, add the attributes from the obj
            doc.Objects.AddInstanceObject(idef_index, instance.Xform, attributes);
// Add everything else
    // These objects are used as part of instance definitions
    // We probably don't want to add them to the model
    // So we skip them
    if (attributes.IsInstanceDefinitionObject)
        continue;
Key changes:
  • Add attributes to doc.InstanceDefinitions.Add, this might be unnecessary but probably a good idea to ensure they match from the original model
  • We now use AddInstanceObject within the foreach loop that creates the InstanceDefinition, and use the index of the definition we added to the current RhinoDoc, not the index of the definition from the loaded model.
  • Add attributes when using AddInstanceObject, otherwise layers and other attributes won’t transfer over.
  • When adding “everything else” skip over objects that are used as part of InstanceDefinitions – these aren’t normally part of the model
That said, this won’t work for nested blocks (which you should probably make it work for). Its a little more complicated as you’ll need to creating a mapping between top level definitions and their respective nested definitions…
Hope this helps!
– Luke.
I have created a python variation of the function that uses an iteration on nested blocks. Still i ran into a different problem regarding the object attributes:
For linetypes with the same name, the linetypeIndex may differ between the active and the imported file. In my setup some imported objects had a wrong linetyp, since the indexes didnt match between the files. I have got a solution for the problem, but there might be more similar problems with the attributes:
def importBlockInstanceFromFile(filePath, blockname):
    def myfunction(idef):
        objectIds = idef.GetObjectIds()
        for objectId in objectIds:
            obj = rhino_file.Objects.FindId(objectId)
            if obj.ComponentType == DocObjects.ModelComponentType.InstanceDefinition:
                myfunction(obj)
            else:
                name = idef.Name
                description = idef.Description
                basePoint = Geometry.Point3d()
                geometry_list = [rhino_file.Objects.FindId(id_).Geometry.Duplicate() for id_ in idef.GetObjectIds()]
                attributes_list = [rhino_file.Objects.FindId(id_).Attributes.Duplicate() for id_ in idef.GetObjectIds()]
                for att in attributes_list:
                    #Find linetype in the imported file
                    linetypeRef = rhino_file.AllLinetypes.FindIndex(att.LinetypeIndex)
                    if linetypeRef:
                        linetypeNameRef = linetypeRef.Name
                        linetype = RhinoDoc.ActiveDoc.Linetypes.FindIndex(att.LinetypeIndex)
                        linetype_Name = linetype.Name
                        if linetypeRef is not linetype_Name:
                            correctIndex = RhinoDoc.ActiveDoc.Linetypes.FindName(linetypeNameRef).Index
                            if correctIndex: att.LinetypeIndex=correctIndex
                RhinoDoc.ActiveDoc.InstanceDefinitions.Add(name,description,basePoint,geometry_list,attributes_list)
    #read the 3dm
    rhino_file = FileIO.File3dm().Read(filePath)
    #get table of objects in the 3dm file
    idef = rhino_file.AllInstanceDefinitions.FindName(blockname)
    myfunction(idef)
Does anyone have a better solution to deal with this?
best Peter
@peter.zock I can’t think of anything clever off the top of my head.
My only thought would be if you want to guarantee that the correct linetype/hatch/group/material is used you could loop through and transfer these to new model from your imported model, and then when importing the block, you would lookup something like the linetype by name, rather than by index.
This is kinda similar to how Rhino handles duplicate block imports, where if there’s a block with the same name in the model (i.e. Block A) it will ask if you want to keep both, and if you agree, it will will rename the imported block to Block A 01. In the same way you could add 01 to all the imported linetypes to ensure there’s no conflict (although this assume that 01 is unique enough that its unlikely to already exist in the model, if you’re importing blocks from different models it would likely only work for the first import… you can make this as sophisticated as you wanted though if that’s a potential problem, using something like GetUnusedLinetypeName). Then when importing your block, when it came to setting the linetype you would know that the correct linetype name is {linetype_Name} + 01. If you ended up using GetUnusedLinetypeName then you would have to keep track of what the original linetype index/name was to map to the new linetype index.
This has the downside that you’ll end up with duplicates of any of the standard linetypes, but you could probably extend this to check if any of the linetypes were the standard Rhino linetypes or even just check if there’s any of the imported linetypes match existing linetypes and only import/add if they’re truly unique and have a clashing index.
Hope this helps ~
Thanks for you reply! I guess one day I will try to make a proper function based on your proposal. For now I have another solution:
def importromFile(filePath):
    # Get the starting object runtime serial number
    start_sn = DocObjects.RhinoObject.NextRuntimeSerialNumber
    #Import file
    RhinoDoc.ActiveDoc.Import(filePath)
    # Get the ending object runtime serial number
    end_sn = DocObjects.RhinoObject.NextRuntimeSerialNumber
    #Delete all objects that are not beeing used in a InstanceDefinition
    rh_objects=[]
    for sn in range(start_sn, end_sn):
        rh_obj = sc.doc.Objects.Find(sn)
        if rh_obj:
            if not rh_obj.IsInstanceDefinitionGeometry:
                sc.doc.Objects.Delete(rh_obj,True,True)
            else:
                rh_objects.append(rh_obj)
    return rh_objects
Its more slow, but does manage the mapping under the hood;
    #Import file
    rh_objects=[]
        if rh_obj:
            else:
    return rh_objects
Update:
The RhinoDoc.ActiveDoc.Import(filePath) doesnt handle nested blocks very good. For the nested blocks it will create duplicates. So just in case somenone is interested into this, here is my updated version that can handle nested blocks and that will match layers and linetypes:
Still importing stuff this way feels kind of hard
#! python 3
from Rhino import Geometry, DocObjects, RhinoDoc, FileIO
import scriptcontext as sc
def import_InstanceDefinition_FromFile(filePath):
    def reassign_attributes_indexes(attributes_list):
        for attributes in attributes_list:
            if attributes.LinetypeIndex > -1:
                key = importFile.AllLinetypes.FindIndex(attributes.LinetypeIndex).Name
                if key in dic_attributes_match.keys():
                    attributes.LinetypeIndex = dic_attributes_match[key]
            if attributes.LayerIndex:
                key = importFile.AllLayers.FindIndex(attributes.LayerIndex).Name
                    attributes.LayerIndex = dic_attributes_match[key]
    def importBlockInstance(idefgeometry):
        objectIds = idefgeometry.GetObjectIds()
        geometry_list=[]
        attributes_list=[]
            rhobj = importFile.Objects.FindId(objectId) #Get the objects in the InstanceDefinition
            if rhobj.Geometry.ObjectType == DocObjects.ObjectType.InstanceReference: #If one of the object is ObjectType.InstanceReference:
                #Get the parent InstanceDefinition
                parentIdefId = rhobj.Geometry.ParentIdefId
                parentIdef = importFile.AllInstanceDefinitions.FindId(parentIdefId)
                #Add the parent InstanceDefinition to the active doc if not existing already
                if not sc.doc.InstanceDefinitions.Find(parentIdef.Name):
                    importBlockInstance(parentIdef)
                parentIdef_new = sc.doc.ActiveDoc.InstanceDefinitions.Find(parentIdef.Name) #Get the new copy of the parent InstanceDefinition in the doc
                geometry_list.append(Geometry.InstanceReferenceGeometry(parentIdef_new.Id, rhobj.Geometry.Xform)) #Get the geometry base
                attributes_list.append(rhobj.Attributes.Duplicate()) #Get the attributes
            else:
                geometry_list.append(rhobj.Geometry.Duplicate())
                attributes_list += [rhobj.Attributes.Duplicate()]
        #Reassign index
        #Add the InstanceDefinition to the active doc
        idefName = idefgeometry.Name
        description = idefgeometry.Description
        index = sc.doc.InstanceDefinitions.Add(idefName,description,basePoint,geometry_list,attributes_list)
    importFile=FileIO.File3dm.Read(filePath)
    if importFile:
        dic_attributes_match = {}
        for layer in importFile.AllLayers:
            index  = sc.doc.Layers.FindByFullPath(layer.FullPath,-1)
            if index > -1: #If the layer is already in the doc
                dic_attributes_match[layer.Name] = index
            else: #If the layer is not in the doc it has to be created
                newLayerIndex = sc.doc.Layers.Add(layer)
                dic_attributes_match[layer.Name] = newLayerIndex
        for linetype in importFile.AllLinetypes:
            linetype_match = sc.doc.Linetypes.FindName(linetype.Name) #If the linetype was found, the linetype index, >=0, is returned. If the linetype was not found, -1 is returned. Note, the linetype index of -1 denotes the default, or "Continuous" linetype.
            if linetype_match.Index > -1: #If the linetype is already in the doc
                dic_attributes_match[linetype.Name] = linetype_match.Index
                #print('Layer -' + str(linetype.Name) + '- already in the file, New Index: ' + str(linetype_match.Index))
                newLinetypeIndex = sc.doc.Linetypes.Add(linetype)
                dic_attributes_match[linetype.Name] = newLinetypeIndex
                #print('Layer created. ' + str(linetype.Name) + '; New Index: ' + str(newLinetypeIndex) + ', Index in the imported file: ' + str(linetype.Index))
        for idef in importFile.AllInstanceDefinitions:
            if not sc.doc.InstanceDefinitions.Find(idef.Name):
                importBlockInstance(idef)
if __name__ == "__main__":
    import_InstanceDefinition_FromFile(yourFilePath)
