I want to implement a function like ARQ Style.
So first I use the command mmaBlockDef to generate a file include two blocks in its AllInstanceDefinitions property.
And then by command mmaBlockRestore I want to import blocks from the file and add them to current doc, but I don’t know how to implement, can you help me? thank you
My rhino is 7.2, and use rhino common, here is my code
namespace MMArc
public class MMArcBlockDef : Command
public override string EnglishName => "mmaBlockDef";
var path = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);
var filename = Path.Combine(path, "testBlocks.3dm");
Result rc;
using (var file = new File3dm())
var layer0 = new Layer { Name = "Default", Color = Color.Black };
file.AllLayers.Add(layer0);
var layer_index = file.AllLayers.Count - 1;
var att = new ObjectAttributes { LayerIndex = layer_index };
//first block
Point3d base_point = new Point3d(0, 0, 0);
string idef_name = "mmBlock01";
var geometry = new List<GeometryBase>();
var attributes = new List<ObjectAttributes>();
for (var x = 0; x < 10; x++)
var line_curve = new LineCurve(new Point3d(x, 0, 0), new Point3d(x, x * 10, 0));
geometry.Add(line_curve);
attributes.Add(att);
file.AllInstanceDefinitions.Add(idef_name, string.Empty, base_point, geometry, attributes);
//second block
string idef_name = "mmBlock02";
var line_curve = new LineCurve(new Point3d(x, 0, 0), new Point3d(x, x * 5, 0));
//write 3dm file
rc = file.Write(filename, 7) ? Result.Success : Result.Failure;
return rc;
/// <summary>
/// read the .3dm file, and add its blocks into doc.InstanceDefinitions
/// </summary>
public class MMArcBlockRestore : Command
public override string EnglishName => "mmaBlockRestore";
var file = new File3dm();
file = File3dm.Read(filename);
//??? How to add all InstantsDefinitions items in file to current doc ????
/*for (int i=0; i< rfile.AllInstanceDefinitions.Count; i++)
var ins = file.AllInstanceDefinitions[i];
doc.InstanceDefinitions.Add()
Transform xform = Transform.Identity;
doc.Objects.AddInstanceObject(0, xform);
doc.Views.Redraw();
return Result.Success;
