Can you create say like a new physical material and change that to be the default material for all new surfaces?
You can’t alter the default material type yet but we have that down as a feature request. A workaround would be adding custom materials to a new blank file that you SaveAsTemplate and then start new projects with. You would set the materials to be used by all layers in the template effectively changing the default material used for anything you modeled.
