Chance Default Material Color
Is there a way to change the default material color from white to a color of choice. I constantly change the material color to a gray to reduce glare but it would be nice if that was the color to begin with…
Materials are file-specific (as opposed to Rhino “app”-specific). Change the materials in the file that you use when you start Rhino and save as your new template. Then set this template to be loaded when Rhino starts.
Thank you Wim for the reply… Not to be too brain dead here but I have tried to figure out where to start, but am at a loss. Would you be willing to step me through the process?..
I worked my through it and got it figured out… Thanks again Wim
