Does is is Copy & Past from Rhino wip 8 to autocad possible or foreseen?
Wolf
Wolf
Just doing a little poking around…
This is not something I have ever done but I do have a copy of AutoCAD 2018.
When I copy anything in V6 and V7 and try to paste it in AutoCAD, I get an image.
In V8, if I copy super simple geometry; a circle and a rectangle in this case, I can paste them into AutoCAD 2018.
If I select something that has to be interpreted into something else for AutoCAD’s limited object types; Extrusion, closed BREP, degree 3 curve for example, pasting into AutoCAD again results in an image, no geometry.
That’s what I can see now.
Does is is >>> Is
I changed the title
Please make a YT issue for this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-72725/Support-Copy-from-Rhino-V8-Paste-into-AutoCAD
I could copy past some objects, like curves and text, yesterday but today it was not anymore possible. Instead i got an image. I will make some test tomorrow.
That’s what I found. If I included anything other than straight or circular lines, I got the image too.
