Hi there
Since an update (sadly don’t know when) the functionality of copy/pasting from Illustrator and into rhino stopped working, the other way around still works though.
Hi there
Just a little bump here. Any information about this?
I just fixed this today. The latest version of Illustrator slightly changed the format of data that it saves in the clipboard and this was causing Rhino to fail during a paste operation. Thus fix will be in 7.13 which we should have an initial release candidate for next week.
RH-65824 is fixed in Rhino 7 Service Release 13
Can objects be copy/pasted from illustrator to Rhino? If so, is there a list somewhere of apps where copy/paste can be used to insert data into Rhino? I know it doesn’t work from my other main packages ACLT, Sketchup and CorelDRAW.
Supported file formats: Rhino - Supported File Formats The associated software list does not appear to comprehensive. Some formats are used by software which is not listed.
Copy/paste works with applications that place SVG content into the clipboard. I know Affinity Designer, Illustrator and Inkscape do this
Thanks for the info. However, that’s a list of possible import/export formats. Perhaps I misunderstood the OP? I read it to mean he could copy objects in Adobe Illustrator, and paste into Rhino. I wondered if that was possible with other software since I can’t do it with any that I use. Most importantly AutoCAD.
We do not currently support copy and paste between Rhino and Autocad
Yep. What I wondered about was a list of software where copy/paste is supported.
Currently just 3dm and svg formats. I’m hoping to expand on this in Rhino 8, but it will take quite a bit of work
Great news!! Thanks
This would really really help!
(AutoCAD stubbornly refuses to vanish from the face of the earth…)
