Hi everyone,
How can i model such pattern, could u please help me
if you only need one panel, it’s probably faster to do it by hand.
otherwise, start from a standard grid, selectively add lines inside the cells, then rotate 45 degrees, fit to a frame and trim, do a curve boolean to get inner regions (Parakeet3D has a neat component for that), offset them inwards, and pass the curves to a BoundarySurface component, and extrude that surface.
