Hi everyone,
can you tell me why the geometry is invalid?
He did not encounter any errors in the construction phase.
Thank you.
It happens often with Dendro outputs. Since Rhino V6, Rhino is more stringent with mesh validity.
You can play with the I Isovalue settings of Dendro and also the adpativity (set to 0). And also the steps.
You could also try to smooth the mesh using Dendro Smooth.
Or repair mesh inside Rhino.
This is the fourth thread from you on this subject!
Hello everyone,
I ask if there is a function that allows you to orient each single edge of the structure by defining a certain angle of inclination.
Thanks.[Mesh_edges] [Struttura]
Hello, I’ve been using Grasshopper a few months ago.
I need some advice about designing a foam, as generating the .STL file creates triangularization problems, as shown in the figure and normal non-unified meshes. I also had some advice on modeling without requiring supports in the printing phase with additive techniques.Foam_stochastic.gh (26.4 KB) [stl.PNG] [supporti.PNG]
Hi everyone, I am facing this problem.
Is it possible to reconstruct a mesh with the curve to volume function of dendro, obtaining a cellular structure? I tried but it can only generate a small portion of the surface.
Thank you
[Cattura] [Cattura1]
