After reading some posts here about Dendro I decided to try it for the first time. To do that I used pieces of GH files I’ve used before that contained no meshing routines at all. It was an interesting learning experience for sure, and it brought up what might be considered a quirk in the way meshes function.
Because this was my first experience with Dendro I opted to start with small geometry that looks like this:
On the left are 5 feet formed from 5 closed Breps, and on the right is the top, also a closed Brep.
Here is a screenshot of the attached GH file which I simplified by internalizing the above geometry:
The interesting part is the final Invalid mesh. Even though it is Invalid it can be baked into Rhino and then exported as an STL file for 3D printing. Here is a photo of the printed part:
Even though GH/Dendro says the final mesh is invalid, it displays just fine in Rhino. I thought this was interesting, but it got even more interesting when I tried to Bake it:
Whoa baby! I had never seen this dialog before - probably because I stick to closed Breps almost exclusively. But I figured what the heck, let’s Bake it and see what happens.
This is what happened:
Needless to say, that got my attention. But much to my surprise it exported as an STL just fine. And when I imported that STL file into my slicer (SuperSlicer) it reported that it found and corrected 4 mesh errors, and then subsequently sliced the result with no problems. My printed result is what I showed above.
So - I’m not sure what all this is trying to tell me. Since I deal only with 3D printable geometry the issue of invalid meshes that actually work may be of value only to me, but maybe this little example might help someone else for whom meshes are a big deal.
InvalidMesh-maybe.gh (619.2 KB)
