Hello! I am trying to create a smooth surface throught with the command interpolate curve through points. Nonetheless, the curves don´t go all the way through to the end. The origin lines are actually one line split in two, I don´t know if this is the correct way to get the surface, but it is the only one I know since you cant loft a surface with open and closed curves. Thanks in advance
arcos3.gh (13.8 KB) Curvas2.3dm (92.1 KB)
