I am trying to clear my system and the uninstall is not working with the error code, so I tried using the repair option in the installer and have found the same error message.
Please let me know how it can be resolved
Hi asmm7,
Please do these 4 things:
- Run the combined 2015, 2017, and 2019 installer using this link from Microsoft:Latest supported Visual C++ Redistributable downloads | Microsoft Learn the 64-bit tool since Rhino is a 64-bit application.
- Run the .NET repair tool from Microsoft:https://www.microsoft.com/en-us/download/details.aspx?id=30135
- https://www.microsoft.com/en-us/download/details.aspx?id=30135
- Repair Rhino:
- Windows Control Panel
- Add/Remove programs
- Select Rhino
- Click Change
- Click Repair
Hi Japhy, I tried these steps but it showed the same error again.
Please click on the red link for the log file and send it to tech@mceel.com.
Thanks
Thanks to the team for the solution.
Fix problems that block programs from being installed or removed - Microsoft Support this helped me with the problem.
