I need to make a Rhino plugin install
using inno setup since a bunch of other stuff needs to installed and checked
I have made it in the past with success writing into the registry editor
all relative info, but it seems that this does not work on RH7 or I am missing something
I am filling the HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\7.0\Plug-ins
all seems to be correct but looking into the plugin list of Rhino
the software does not bring up
Question: How to install a plugin correctly with relative rui ?
Hi Travis
Yep, this is what I am doing, checking registry all seems to be written correctly
but Rhino does not load or report the name in the plugin dialog
Maybe I have to signal a new plugin has been installed ?
I have checked several times but unable to get it to work
In the Plugin subdirectory what is your plugins Filename set to? This should be the path to the plugin. You shouldn’t need to supply the command list, Rhino will handle those additional registry entry details. The 2 registry entry examples I posted above are enough to make Rhino load the plugin.
If you load the plugin manually via PluginManager you can then export your plug-ins registry entries as a .reg file and import that into Inno to test if you’re having issues.
