Hello
I made these 3D inset/outset (images below) in Blender.
Is there a command in Rhino 8 that does these operations?
Thanks
Hello
Thanks
In Rhino V8 there’s a command called “pushpull” that basically does the same thing.
How can we know that all the edges of a polysurface are glued? And that there are no surfaces left?
How can we subtract coplanar faces in a polysurface?
Thanks
if you select the object it should report: 1 closed polysurface added to selection. should it be open and you want to find out where exactly you also have the ShowEdges command.
i am not fully sure i understand, but you can merge coplanar faces with MergeAllCoplanarFaces.
