This command is not documented. How does it work?
Hi John - I’ll check the docs - it should be in there… the command can be used whenever a plane is legitimate input in a command - Trim, Split, Intersect would be common ones but it also works with say, FilletSrf and other commands that accept a plane. To use it, at the point when Rhino is asking for a selection, type in ‘InfinitePlane’ (or just ‘IP’) and Enter, then choose one of the plane options to define the plane you want to use.
It does not show in the interactive Help panel.
Link your Help to online version:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#information/welcome_to_rhinoceros.htm#(null)
