Hi All,
Can anyone tell me in python how I can create several Iplanes (infinite plates) from a selection of (planar) surfaces that I can later reference to split my target surfaces?
Thanks in advance!
Hi All,
Thanks in advance!
Hi @g.synetos,
Perhaps this give you a few ideas?
import Rhino
import scriptcontext as sc
def _planarsrf_plane(geometry):
face = None
if isinstance(geometry, Rhino.Geometry.Brep) and geometry.IsSurface:
face = geometry.Faces[0]
elif isinstance(geometry, Rhino.Geometry.BrepFace):
face = geometry
if face:
rc, plane = face.TryGetPlane()
if rc:
return plane
return None
def _planarsrf_filter(rhObject, geometry, ci):
plane = _planarsrf_plane(geometry)
if plane:
return True
return False
def test_sel_planarsrf():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select planar surfaces")
go.SetCustomGeometryFilter(_planarsrf_filter)
go.GetMultiple(1, 0)
if go.CommandResult() != Rhino.Commands.Result.Success:
return
planes = []
for objref in go.Objects():
geometry = objref.Geometry()
if geometry:
if plane:
planes.append(plane)
for plane in planes:
print(plane)
if __name__ == "__main__":
– Dale
Hi @dale,
Thanks for the scirpt.
For the attached example I had to change the isinstance check from and to or.
Also i bypassed the _planarsrf_filter as it was popping an exception error.
Any suggestion on how to make the created panels to be inside the bounding box of the visible geometry similar to the IPlane command?
The modified script below
import Rhino
face = None
if isinstance(geometry, Rhino.Geometry.Brep) or geometry.IsSurface:
face = geometry
if face:
if rc:
return plane
return None
if plane:
return True
return False
# go.SetCustomGeometryFilter(_planarsrf_filter)
return
planes = []
if geometry:
if plane:
# print(plane)
rs.AddPlaneSurface( plane, 1000, 1000 )
